Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter Set
666067
666067
- 12 piece set consists of:
- 3 x Two Flute straight cutters 6, 12 & 16mm dia
- 2 x Bearing Guided Rounding Over cutters
- 6.3mm & 9.5mm Radius
- 1 x V Groove cutter
- 1 x 4mm Radius Ogee cutter
- 1 x 6.3mm Radius Box cutter
- 1 x 6.3mm Radius Cove cutter with bearing
- 1 x 45° Chamfer cutter with bearing
- 1 x Template Profile cutter with bearing
- 1 x 12mm Dovetail cutter
- Show More
Axcaliber A5 Foam Router Cutter PresenterSpecial Price £4.30 £3.58 was £13.58 £11.32 Save £9.28 £7.73
Show more
Show less
A superb long shank cutter set introduced for use on those router tables where the thickness of the table or insert limits the full depth of cut. Each shank is clearly marked with the correct depth of insertion into the router collet for safe usage. Shanks are 36mm in length, useful when using a router table or when a sub base has increased the thickness of the router base.
EAN Barcode | 5052511029419 |
