Axcaliber CutPro TCT Saw Blade Neg Rake - 305mm x 2.5mm x 30mm 72T
104001
Special Price £48.94 £40.78
was £113.98 £94.98 Save £65.04 £54.20
4 Reviews
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
  • 72T negative rake TCT saw blade
  • 35° top bevel angle for outstanding finish and performance
  • 5° negative rake, especially suited to mitre saws
  • Micro-grained TCT tips for a sharper, longer lasting edge
  • Tensioned, pre-stressed, quality steel plates guarantee true running
  • Resin filled, laser cut slots reduce noise when cutting
  • 30mm bore, reducing bushes available
To produce your best work you need to cut with the best blades
Axcaliber CutPro Circular Saw Blades use the latest production techniques and the finest materials. Cut at a more controlled pace for a neater cut using your mitre saw and experience longer runtimes and less strain on your cordless plunge or handheld circular saws.
Designed for a first class result in all natural timbers and man-made boards, this blade is the perfect choice for professional use. It is particularly suited for mitre saws and would also suit workshop circular saws where a fine cut is required, particularly in laminate or faced boards.
The 5° negative rake enhances safety by giving a smooth start and preventing the blade from grabbing. It offers the benefit of cutting at a more controlled pace for a neater result. The 35° alternate top bevel angle gives you an outstanding quality cut, even in timbers normally considered difficult. In effect this 35° angle creates a shear cutting action, resulting in a clean, splinter free finish.
Axcaliber CutPro circular saw blades use the latest production techniques and the finest materials. The blades feature micro-grained TCT tips. The resin filled, laser cut plates substantially reduce noise while cutting. A faint tensioning ring halfway across the plate indicates where each blade is individually pre-stressed, to guarantee smooth running.
The bore size is 30mm; various bore reducing bushes are available.
5.00 4
