Axminster Professional Master Precision Tape
102569
From £10.38 £8.65
  5. Half Star
28 Reviews
Low Stock - Ready to dispatch
  • Class 1 accuracy – the most accurate tape measure available
  • Heavy duty, impact resistant case
  • Positive blade lock
  • Blade pause button
  • True zero tip
  • Belt clip
  • Metric and imperial graduations
The Axminster Professional Master Precision Tape is made to Class 1 accuracy, making it one of the most accurate conventional tape measures available. This tape is ideal for cabinetmakers, joiners and anybody who needs an accurate measurement every time. The standard blade lock is complemented by a pause button which gently holds the blade into position. Encased in a bevelled, impact resistant case which is small enough to fit comfortably into your pocket. Available in 5m length, blade width 25mm. Metric and imperial graduations.
4.40 28
