Axcaliber FineLine PTFE Coated Handsaw
- Triple diamond ground FineLine teeth, super sharp and long lasting
- Rigid blade with low friction, rust resistant PTFE coating
- Heavy duty soft grip comfort handle
- Choice of length and tpi
These razor sharp, triple diamond ground teeth cut with amazing speed. The blades are made from 1mm thick steel and have a low friction PTFE coating that also protects against corrosion. The teeth are electronically hardened and diamond ground. The saw is fitted with a heavy duty two part comfort handle that incorporates 45° and 90° angles. Perfect for both indoor and outdoor protected timbers.
Blade Thickness | 1.00 mm |
