Axcaliber FineLine PTFE Coated Handsaw 7tpi - 550mm (Pkt 5)
- Great value package deal; 5 x 7tpi 550mm (22") FineLine saws
- Triple diamond ground FineLine teeth, super sharp and long lasting
- Rigid blade with low friction, rust resistant PTFE coating
- Perfect for tanalised protected timbers
- Heavy-duty soft grip comfort handle
Pull and push
Each tooth has three cutting edges. This tooth design produces a fast and very clean cut, both on the pull and the push stroke.
A saw for all seasons
The low friction PTFE coating not only protects the blade from corrosion, it also makes it glide through even wet timbers.
Staying sharp for longer
The technologically advanced diamond grinding process ensures a precise tooth form, with impulse hardening offering greater durability and longer life.
More than a saw
Fitted with a heavy duty two part comfort handle that incorporates 45° and 90° angles for fast marking out.
Package deal comprises 5 Axcaliber FineLine PTFE coated handsaws, 550mm x 7tpi.
These razor sharp, triple ground teeth cut with amazing speed. The blades are 1mm thick steel with a low friction PTFE coating that also protects against corrosion. The teeth are electronically hardened and diamond ground. The saw is fitted with a heavy-duty two part comfort handle that incorporates 45° and 90° angles.
EAN Barcode | 5052511122851 |
Blade Thickness | 1.00 mm |
Length of Blade | 550 mm |
Tooth Pitch \ tpi | 3.63 mm \ 7 tpi |
