Axcaliber Rebate Cutter Set
- Diameter 35mm
- Depth of cut 12.7mm
- Shear cut for best finish
- SAE4140 steel shank hardened to Rockwell 45 HRC
- Diamond ground Sandvik micrograin tungsten carbide tip
- Virtual mirror finish ensures durable, clean cutter
- PTFE coating helps minimise resin build-up
A very popular rebate set available in 1/4"(6.35mm) or 1/2"(12.7mm) shank sizes, which include four different bearing sizes offering the following depths of rebate: 12.7mm(1/2"),11mm(7/16"), 9.5mm(3/8"), 8mm(5/16"), with a depth of cut up to 12.7mm(1/2"). The carbide tips are set at an angle to give a clean shearing cut.
