Axminster Woodturning Short Handle
104151
Special Price £35.98 £29.98 was £44.98 £37.48 Save £9.00 £7.50
17 Reviews
In Stock - Ready to dispatch
  • 12-13mm ER20 collet, firmly grips onto a 12.7mm(1/2") diameter round bar
  • Collet nut has a fine thread, producing a secure grip even when tightened by hand
  • Aluminium shaft with comfortable medium/hard foam covering
  • Covering is durable, comfortable and gives a positive non-slip grip
  • Overall length of 345mm (13.1/2")
  • Includes a C-spanner and tommy bar to release the nut if required
Which tools can I use?
The handle firmly grips any turning tool with a bar diameter between 12mm and 13mm. The ER20 collet is interchangeable; if you need to grip a different diameter bar, then simply buy a suitable size collet.
Axminster Woodturning Probes
Available in Straight and Offset versions, these tools are perfect for turning boxes, goblets and small hollow forms. The Offset tool includes a cranked shape for undercuts and deeper access.
Crown Cryo Tools
The double-ended bowl gouge is great value with fingernail and straight grinds. Why not re-grind the edge profiles to suit your particular style or needs?
The modular design of the Crown Revolution offers even greater flexibility and is supplied with 6 cutters.
Choose your tools from the Recommended Accessories section!
This Axminster woodturning handle is the short version with an overall length of 345mm (13.1/2"). (Long version is product code 102428). The aluminium shaft has a comfortable medium/hard foam covering. The covering is durable, comfortable and gives a positive non-slip grip while you are turning.
The business end has a 12-13mm ER20 collet, which firmly grips onto a 12.7mm(1/2") diameter round bar. Originally intended for use with 12.7mm double-ended turning gouges, you can of course grip any turning tool whose bar diameter is between 12mm and 13mm. ER20 collets do not lock up like conventional collets. They are interchangeable; if you need to grip a different diameter bar, then you only need purchase a suitable size ER20 collet. These are available in sizes 2-13mm in 1mm increments. The collet nut has a fine thread, producing a secure grip even when tightened by hand alone.
The Axminster woodturning handle includes a C-spanner and tommy bar to release the nut if required.
British Made British Made
4.80 17
