Axminster Professional AP152OVS Bobbin Sander - 230V
- Versatile sander combines rotation with oscillation
- Smooth sanding of small or large curves, table tilts up to 45°
- Supplied with 50, 38, 16, 12 and 6mm spindles and 100g loadings
A must have buy!
Supplied with 50, 38, 16, 12 and 6mm spindles to cover various projects, this bobbin sander can make many complex curves easy to sand smooth. The bobbin action prevents any burning of the workpiece and extends the life of the abrasive.
So sure are we of the quality of this bobbin sander, we cover all parts and labour free of charge for three years! Find out more
Easy adjustments
The table adjusts from 0° to 45° which allows for accurate sanding. This gives you the flexibility to work on various different projects with ease.
High quality materials
The rigid frame and welded steel chassis aids reduction in vibration for a more comfortable woodworking experience.
Simple storage solutions
There's built in storage for spindles and table inserts meaning you can keep all parts in one place!
Safeguard your health
An ultra efficient extraction hood helps to keep you safe and your workshop clean.
Axminster Workshop Abrasive Belt Cleaner - Large (300 x 50 x 50mm)From £29.18 £24.32
Axminster Professional 76mm Bobbin Sander Spindle AssemblyFrom £112.78 £93.98
A bobbin sander is one of the most useful sanders in any workshop. It is perfect for sanding complex curves, particularly internal large and small radii. The combined action of rotation with oscillation, leaves a very clean finish, prevents burning and extends the life of the abrasive.
The AP152OVS bobbin sander has a ground cast iron table on a steel base. The table adjusts from 0° to 45° and locks securely at the desired angle. There is a 50mm dust extraction outlet; connection to a vacuum dust extractor provides an almost dust free operation.
The machine comes as standard with 6mm, 12mm, 16mm, 38mm and 50mm diameter spindles complete with matching table inserts. The spindles are 152mm in length for the 38 and 50mm sizes and 140mm for the 6, 12 and 16mm. Also available as an additional accessory is a 76mm diameter bobbin, which will require an accompanying table insert.
The supplied abrasives are 100g, there is a large choice of different grits available.
Axminster Professional 3 Year Guarantee
Machine Classification
Bobbin Height | 140 mm & 152 mm |
Dust Extraction Outlet | 50 mm |
EAN Barcode | 5052511124831 |
Max Cap @ 90º | 110 mm |
Model | AP152OVS |
Nett Weight | 30 kg |
Plug Fitted | UK 3 pin plug |
Power | 375 W |
Rating | Trade/Professional |
Spindle Speed | 1,425 rpm |
Stroke Length | 24 mm |
Table Height | 465 mm |
Table Size | 370 mm x 370 mm |
Voltage | 230 V |
