Axminster Professional AP220SM Deluxe Spindle Moulder - 230V
- Comes with 1,400mm sliding table with work clamp and UJK mitre fence
- Router collet chuck with 8mm and 1/2" collets included as standard
- Precision ground cast iron with side extension tables
Customers Also Bought
The Axminster AP220SM Deluxe spindle moulder is designed and engineered to include many features and refinements required on a professional spindle moulder.
This includes an extra heavy duty cabinet, sturdy and smooth spindle rise and fall, massive and accurate cast alloy fence system with safety guards and fine adjusters.
The large table plus the sliding table provide an ample work surface for almost any project. The mitre fence runs in a 19mm T-slot groove machined into the table. For even more support and accurate angle setting a UJK STF-1400 sliding table fence is included.
The 30mm spindle is an HSK-30 quick release type, meaning you can adapt the spindle moulder to take router cutters using the ER20 collet chuck, which comes with the machine.
The 4 belt speeds mean that almost any moulding, slotting or larger diameter routing cutter can be used, subject to the maximum sizes and speeds. This machine has many features found on large, cumbersome machines, all in a compact package.
Note: This machine is not suitable for use with a power feed.
The Axminster AP220SM Deluxe spindle moulder comes with a cast iron mitre gauge, ground cast iron table with side extensions and table insert rings, a UJK STF-1400 sliding table and a centralised control panel.
Perfect for busy workshops.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
