This rack will deal with your storage problem in the best possible way. It will safely store your F clamps, sash clamps and parallel jaw clamps.
The storage slots are 12mm wide and the capacity is up to 12 clamps or 25kg. Made of 2mm thick steel with a painted finish they are unlikely to bend under load or rust over time. Each rack is 600mm long and pre-drilled for fixing on a wall.
This is an ideal companion to the Axminster Professional G clamp rack. Tidy up, gain more workshop space and say goodbye to that heap of clamps in the corner.
Made in the UK.
