Axminster Professional Edging G Clamp - 60 x 50mm
- Clamp edging or lipping to board up to 60 mm thick
- Designed to allow off-centre clamping
- 50 mm depth capacity, max clamping pressure - 250Kg
Titebond III Waterproof Wood Glue - 3.8litres (1 US Gall)From £69.98 £58.32
See the entire range
Edging clamps will clamp a lipping or edging to a board up to 60 mm thick. They have a throat depth of 50 mm. Screws on each side allow for off centre clamping. They are the same high quality as the Axminster Professional G clamp.
Lifetime guarantee.
Max clamping pressure - 250Kg
Clamp Throat Depth | 50 mm |
Clamping Capacity | 60 mm |
Clamping Pressure | 250 kg |
EAN Barcode | 5052511012282 |
