Axminster Professional Mini Bar Clamp/Spreader
- 150mm or 300mm capacity
- 60mm throat depth, 70Kg max clamping pressure
- Convertable, clamping or spreading functions
Titebond III Waterproof Wood Glue - 3.8litres (1 US Gall)From £69.98 £58.32
UJK Air Wedge - Slim 100mmSpecial Price £9.98 £8.32 was £15.98 £13.32 Save £6.00 £5.00
See the entire range
The hi-tech resin body is sturdy as well as temperature resistant and the 686 N clamping force makes for a perfect, lightweight, third hand. The non-marking, stay-on pads protect the work surface. With a jaw depth of 60mm, this is a very useful clamp for those smaller jobs. 70Kg max clamping pressure.
Clamp Throat Depth | 60 mm |
Clamping Pressure | 70 kg |
