Axminster Workshop AW1950B Bandsaw - 230V
- Depth of cut: 135mm with 260mm width of cut
- Rigid, welded body construction allows high blade tension for increased accuracy
- Integrated dual port dust extraction, just one connection port
A great addition to any home workshop, large or small
The Axminster Workshop AW1950B Bandsaw is a premium, compact bandsaw with many new features not normally found on machines of this size.
Buy with confidence
So sure are we of the quality of this saw, we cover all parts and labour free of charge for three years! Find out more
Smooth running
A steel body and balanced aluminium wheels ensures the machine runs very smoothly.
Excellent dust extraction
With dual extraction ports, you can rest assured you’re safeguarding not only your health, but keeping your workshop clean at the same time.
Upper and lower bearing blade guide supports
The ball bearing blade guides make the bandsaw easier to set up and also help to achieve more accuracy when cutting.
Twin trunnion table support
This provides excellent support and aids towards a vibration free cut.
Solid fence
A cam locking fence allows for accurate cuts. For convenience, it can be used either side of the blade.
Optional mitre fence
A standard 19mm mitre fence slot provides the option for many optional accessories to be used.
How to get the best out of your AW1950B
Learn how to set it up for accurate cuts
Our experts show you everything you need to know, right through to making your first cut!
Choose a selection of Axcaliber blades
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
Axminster Workshop AW1950B Bandsaw Blade & Mitre Fence KitFrom £49.98 £41.65
Axcaliber Ground Tooth Bandsaw Blade 1,950mm(77") x 6.3mm 6 TpiFrom £14.28 £11.90
Axcaliber Ground Tooth Bandsaw Blade 1,950mm (77") x 9.5mm 6 TpiFrom £14.48 £12.07
Axcaliber Ground Tooth Bandsaw Blade 1,950mm(77") x 12.7mm 6 TpiFrom £14.88 £12.40
Axcaliber High Carbon Bandsaw Blade 1,950mm(77") 4.8mm 10 TpiFrom £15.88 £13.23
The AW1950B is a compact bandsaw with many features not normally found on machines of this size.
It gives you a 135mm maximum depth of cut. It has a strong welded and braced steel frame along with a generously sized cast iron table with a steel plate rear extension. The widely spaced mounting trunnions underneath the table give extra table support and ensure that the table tilt is a smooth operation. A standard 19mm mitre fence slot is provided. The rip fence cam-locks solidly to the front rail and is adjustable to the blade for accuracy. Twin scales allow the fence to be used on either side of the blade.
The bandsaw has ball bearing side and thrust guides; these give great support and are very easy to set up. Once set, they stay set unless you change the width of the blade. A rack and pinion system adjusts the upper blade guide height.
The dust extraction is via two ports, one close to the bottom guides, the other in the lower wheel cabinet. An interconnecting hose means just one 63mm connection port needs coupling to a suitable vacuum extractor. There are twin blade speeds, giving flexibility for many jobs. A powerful induction motor with a multi V belt drives the bandsaw and is quiet and reliable.
Supplied with a steel leg stand with rubber feet and a UK made blade (10mm x 6 TPI Skip Tooth). This could be the perfect bandsaw for most "shed-in-the-garden-garage-workshops".
Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
Bandsaw Blade Length | 1,950 mm (77") |
Bandsaw Wheel Diameter | 270 mm |
Blade Speed | 660 & 840 m/min |
Blade Width Min\Max | 6 mm to 13 mm |
Dust Extraction Outlet | 63 mm |
EAN Barcode | 5052511124541 |
Max Cutting Height | 135 mm |
Max Width of Cut | 260 mm |
Max Width of Cut with Fence | 185 mm |
Min Extraction Airflow Required | 390 m³/hr |
Model | AW1950B |
Nett Weight | 39 kg |
Overall L x W x H | 790 mm x 620 mm x 1,570 mm |
Plug Fitted | UK 3 pin plug |
Power | 550 W |
Rating | Home Workshop |
Sound Power Level LwA [Uncertainty K] | 90 dB(A) [1.5 dB] |
Sound Pressure Level LpA [Uncertainty K] | 82.2 dB(A) [1.5 dB] |
T Slot Size | 19 mm x 9.5 mm (3/4" x 3/8") |
Table Height | 1,035mm |
Table Height on Stand | N/A |
Table Size | 350 x 330 mm |
Table Tilt | 0° - 45° |
Voltage | 230 V |
