The Bosch C470 Delta sheets are suitable for use on wood, paint, varnish, filler, metal and more. The abrasive particles are semi-friable long lasting aluminium oxide grit. A calcium stearate coating minimises clogging, an especially useful feature when working on a painted surfaces or other materials that tend to clog.
These sheets give a perfect finish at high speed and are compatible with delta sanders from Bosch, DeWALT and others. The hook and loop backing offers rapid sheet changes. You can re-attach and reuse part used sheets making them even more economical. The pre-punched holes allow the use of dust extraction further extending the life of the sheet.
Single grit packs comprise 5 sheets; the mixed pack contains 6 sheets, 2 each of 60, 120 and 240 grit.
