Bosch GCM 8 SJL 216mm Slide Mitre Saw and GTA 2600 Stand - PACKAGE
717430
From £579.98 £483.32
49 Reviews
Low Stock - Ready to dispatch
  • Powerful slide saw and adjustable work stand - a total workstation!
  • GCM 8 SJL Sliding Mitre Saw
  • Large cutting capacity with precision laser (70 x 312mm at 90°)
  • Simple, quick and exact set-up
  • Crosscut, mitre/bevel or compound cutting
  • Rebate and groove depth stop
  • Mitre set from front scale, quick set indents, adjustable and front locking
  • Bevel set and locked via side lock lever, common angle turret stop
  • Braked 1,600W soft start motor, two-point dust extraction outlet
  • Fitted with a laser, the cut line is always sharp and clear
  • Table has intergrated side fences that pull out to aid work support
  • Top carry handle for easy transport
  • Supplied with 48T TCT blade
  • 3 year warranty available (registration required)
  • GTA 2600 Folding Leg Stand
  • Fully adjustable work supports for supporting timber left and right
  • Easily folds for transport and storage
  • Supplied with 2 tool clamps
  • Stand length (supports closed) 1,220mm, extended 2,630mm
  • Show More
A total workstation - GCM 8 SJL Mitre Saw and GTA 2600 Adjustable Stand
The powerful GCM8SJL slide saw gives precise cutting, has a large capacity and is simple to set up making it suitable for a host of cutting tasks for the professional and home user alike. With a cut of 70 x 312mm at 90°, it has one of the largest cutting capacities of any 216mm 8" saw on the market.
Bosch have ensured that every aspect, from set up to cut, is quick, simple and exact. It can be used to crosscut, mitre/bevel or make compound cuts, rebate and groove at a consistent depth. It can also crosscut with a -2° undercut facility. Mitre angles are easily set from front locking arm, use the embossed stainless steel scale with indents for quick setting of common angles (override for extra adjustment). Bevels are set by the accessible side lock lever with a quick turret stop for common 22.5°, 33.9° and 45° angles. Fitted with a laser, the cut line is always sharp and clear.
The braked soft start motor ensures a smooth consistent power whilst dust extraction is designed from two points, one of which travels with the sliding head to maximise waste collected via your extractor. The table has integrated side fences that pull out to aid work support. A top handle is fitted so that the machine can be carried easily. Supplied with 48T TCT blade for clean cutting.
Input Power:
230V = 1,600W
110V = 1,250W
The sturdy GTA2600 folding stand has adjustable work supports, left and right, which are both height adjustable and extendable for length for total work support. The legs have rubber end caps (one adjustable for uneven floors); legs are locked into position in use and can be folded easily for transport. It is supplied with 2 tool clamps and these, once fitted to your machine, clamp simply to the stand with a safety lock.
Warranty Bosch Professional 3 Year Warranty (Registration Required)
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
Registration required within four weeks of purchase. More information can be found on the Bosch warranty website and in the warranty conditions.
4.90 49
