Bosch T101AO Jigsaw Blades Tight Curve Cuts in Wood
AX23410
AX23410
- 1.5mm-15mm thick soft wood, laminated boards, plywood
- Especially suited to tight curved corners
- Available in packs of 5 or 25
Show more
Show less
1.5mm to 15mm thick soft wood, laminated boards, plywood especially suited to tight curved corners.
Blade Type | HCS, Ground and Taper Ground |
Jigsaw Blade Length | 51 mm |
Jigsaw Blade Type | Tight Curves |
Max Cutting Depth | 15 mm |
Tooth Pitch \ tpi | 1.40 mm \ 18 tpi |
#AxminsterTools
