Bow 36" XT XTENDER Fence
110670
Special Price £127.48 £106.23 was £149.98 £124.98 Save £22.50 £18.75
3 Reviews
In Stock - Ready to dispatch
Unused returns, open-box items, or cosmetically imperfect products, fully inspected and offered at a discount: Bow 36" XT XTENDER Fence (Cosmetic) *Outlet*
From £127.48 £106.23
  • Upgrade and extend compact saw fences
  • Clamps quickly to existing fences
  • Heavy duty aluminium extrusion for durability
  • Enhance versatility: tall fence, T-slots for accessories
Unparalleled control, precision, and versatility
The revolutionary BOW XT Xtender Fence range will become your number one companion when it comes to sawing. Here are the key components that make it so impressive:
The fences
Strong, rigid and durable, the fences are engineered in heavy duty aluminium extrusion and are available in 24”, 36” and 46”. They will extend your existing saw fence by these lengths respectively, drastically improving your support on any site saw, compact table saw or bandsaw.
The clamps
Coming as a pair, these classic T-Track clamps are designed perfectly for the XT Xtender range. They slot securely into the milled T-tracks of the fences.
The feed supports
Able to be positioned in front of the blade or behind, these supports do just that…significantly improve support for your work. Plus, you can slot a standard 2x4 into the cavity underneath to give even stronger support.
The system
  • Each fence has multiple milled T-slots
  • Effortlessly attach the XT Xtender fence to existing fence
  • Position it best for you: forward/infeed, centre, or back/outfeed
  • Easily set up, remove or change the fence position in seconds
The benefits
  • Remarkably versatile
  • Quick and convenient
  • Use anywhere – onsite or in a busy workshop
  • Easy storage with hanging hole on the fence
Most importantly: better support, better safety, better cut quality, better feed control.
If you're looking for how to extend your table saw fence, the BOW Xtender Fence range is what you need. It's compatible with compact, portable, and cabinet table saws. For your bandsaws, this is the perfect saw fence upgrade to extend small table surfaces, especially when used with the additional feed support options.
Upgrade your saw fence on a wide range of powered saws with the BOW XT Xtender Fences, suitable for compact benchtop table saws, portable saws and bandsaws. Use the BOW Xtender Fence 36" combined with the XT Feed Supports (Pack of 2) as a table saw fence extension kit for your portable table saw - you will transform your saw and drastically improve its capabilities and feed control.
The benefit of using the XT Xtender Fence is unparalleled control and safety when feeding large pieces of timber through your saw. It is remarkably versatile and easy to use - you can set up, remove and change fence positions in seconds, making it incredibly convenient for a busy site or workshop. The XT Xtender Fence is designed with multiple T-slots and attaches effortlessly to your existing fence using two BOW XT T-Track clamps, which are available separately in pairs.
Engineered in a heavy duty aluminium extrusion for durability and strength, it's 36" long, 5" in total height and 1" wide. There is a 4" flat face on the front, ensuring your workpiece glides smoothly along it; as well as a T-slots on the face, top and back for easy compatibility with fence accessories. It features a handy hanging hole for easy storage. Multiple milled slots allow the fence to be positioned in a versatile range of positions: forward/infeed, centre, or back/outfeed.
As well as this 36" size, the BOW XT Xtender Fence is also available in 24" and 46". BOW produce a range of fantastic saw accessories including FeatherPRO Featherboards and PushPRO Push sticks; in the XT Xtender range, there are XT T-Track Clamps (Pack of 2) and XT Feed Supports (Pack of 2).
5.00 3
