Bridge City MT-1 Multi-Tool
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
- Multi-function, adjustable bevel
- Includes 1:8 and 1:6 dovetail saddle squares
- 50mm regular saddle square
- Hardened stainless steel blade for use with marking knife
- Precisely milled aircraft aluminium stock
- Cam-lock mechanism, easy one-handed operation
Exclusive to Axminster
Bridge City Tools enjoy a worldwide reputation for designing sophisticated, highly functional woodworking tools - quality is contagious. For over 35 years they have been changing the rules on how to make traditional hand tools. They are quite simply the standard bearers of the industry. Crafted to the highest of standards using the finest materials, you'd be forgiven for just wanting to display their tools. However, once in the hand and in use, a Bridge City tool will give you the ultimate woodworking experience. Find out more.
200mm adjustable sliding bevel
Bridge City Tools enjoy a worldwide reputation for designing sophisticated, highly functional woodworking tools. The MT-1 Multi-Tool is no exception. Made from aerospace aluminium and stainless steel under strict quality control by Harvey Industries, the MT-I is unique.
This tool will make the most of the space in your tool chest. The MT-1 combines the following functions: a 200mm sliding bevel, a 1:8 dovetail saddle square, a 1:6 dovetail saddle square and regular saddle square. An effective cam-lock holds the stainless steel blade firmly in position. The blade has a 1:8 dovetail cutout and a pencil notch on the tip that allows you to use the MT-1 to draw a line parallel to an edge. The stock, precisely milled from aircraft aluminium, is 112mm long, 22mm wide and 25mm thick at its widest point. All the functions of this positive locking bevel are precise and a pleasure to use.
Blade Length | 200 mm |
EAN Barcode | 854460006252 |
Model | MT-1 |
