Most effective for extraction when connected to vacuum
Supplied as a pack of 2 pads
Starlock mounting for fast work progress and precise results
Compatible with all Oscillating Multi-Tools using the OIS fitting system; FEIN MultiMaster, FEIN MultiTalent, Bosch GOP, Bosch PMF, AEG, Hitachi, Einhell, Makita, Metabo, Milwaukee, Ryobi, Skil, Dremel and others. DeWALT Oscillating Multi-Tools will require an adapter
These perforated delta triangular sanding pads, when used with vacuum extraction, greatly reduce dust in the working environment. This is a pack of two pads.
The FEIN Starlock (patented) oscillating multi-tool mounting system overcomes the disadvantages found with previous designs. Starlock sets the new standard in the oscillating multi-tool market. The design greatly improves the transmission of torque from the motor to the tip of the blade. No more wasted power, means faster working, minimised vibration, the potential for longer blades and better results. Starlock accessories are compatible with all OIS and OIS-compatible power tools currently on the market. Looking rather like a crown bottle top, the raised portion of the Starlock snaps into the next generation of multi-tools, making the system truly tool-less.
