Festool Kapex KS 120 SET-UG Mitre Saw with UG Base & Extensions
- A complete mobile mitre saw workstation
- KS120 REB mitre saw plus UG portable base frame
- Right and left hand extensions with telescopic arms
- Folding UG base frame with transport wheels
- Extensions with measuring scales up to 2,400mm L&R
- Cuts boards and panels up to 305mm x 88mm
Achieve the perfect cut with this impressive sliding compound mitre saw
Additional tool features
For more efficient working, the extra mitre position makes cutting depths up to 120mm possible. Intelligent details like a double laser line and bevel produce exact results.
Even more versatile
Enjoy flexible working thanks to the pull-out extension table and accessories for crown mouldings and wide workpieces.
Ideal for long workpieces
The individual pull-out extension table allows for secure and precise positioning of even long workpieces.
Crown stop
With the crown stop, trimming attachments and base frame, cutting crown mouldings is simple. For convenience, it can also be used as an extension table.
Portable
Offering great portability, the UG base frame provides a stable unit with a working height of 900mm. The saw folds down into the frame, acting as a handle and the two wheels make transportation easy.
Axcaliber Contract TCT Saw Blade - 260mm x 2.8mm x 30mm 60TFrom £37.68 £31.40
Even more versatile
Crown stop
A complete mobile mitre saw package deal comprising a Festool KAPEX KS120 REB mitre saw and a UG portable base frame along with right and left hand extension supports.
KS120 REB Mitre Saw
The KAPEX KS120 REB offers impressive capacity and uncompromising accuracy. It is capable of cutting boards and panels up to 305mm wide and 88mm thick and trimming crown mouldings up to 168 mm in their original wall position.
The KS120 REB features eleven preset mitre angles and a twin-line laser beam. The beams indicate precisely where the blade will cut. Variable speed means you can adapt to different materials for the best cutting performance. The main casting provides a firm foundation for the twin bars, which support the saw head giving the saw its supreme accuracy and solid feel. Pull out side extensions provide extra support to longer workpieces.
The machine comes with a 60-tooth TCT blade, a work clamp and an adjustable bevel, which, transfers angles for interior and exterior angles and dissects angle automatically for easy saw setting. Crown stops (available as an optional accessory) support crown moulding or cornice at the correct angle for cutting perfectly accurate mitre joints.
Base frame (UG - KAPEX) with detachable right and left had extensions
The KS120 REB fits easily onto the UG base frame and forms a stable unit with a working height of 900mm. The saw and frame combination offer great portability. The saw folds down into the frame, the frame acts as a handle and the two wheels make transport extremely easy.
The left and right extensions fit to the base frame, each one is 1,480mm in length and both feature telescopic extensions giving each a maximum support length of 2,400mm, complete with measuring scales.
Benefits
- Includes 36 month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft
- Original parts guaranteed
- 14 day money back
Bevel Angle Range | 47° - 0 - 47° |
Blade Diameter | 260 mm |
Blade RPM | 1,400 - 3,400 rpm |
Bore Size | 30 mm |
Dust Extraction | 27 mm / 36 mm Outlet |
EAN Barcode | 4014549299357 |
Electric Brake | Standard Feature |
Laser Class | Class 2 |
Max Bevel Cut @ 45º W x H | 305 mm x 55 mm |
Max Compound Cut @ 45º W x H | 215 mm x 55 mm |
Max Crosscut @ 0º W x H | 305 mm x 88 mm |
Max Mitre Cut @ 45º W x H | 215 mm x 88 mm |
Mitre Angle Range | 50° - 0 - 60° |
Model | KAPEX KS120 REB |
Motor Power | 1,600 W |
Nett Weight | 21.5 kg (saw only) |
Overall L x W x H | 713 mm x 500 mm x 470 mm (saw only) |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 101 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 88 dB(A) [3.0 dB] |
Spindle Lock | Standard Feature |
Vibration Cutting Wood [Uncertainty K] | 2.5 m/s² [3.0 m/s²] |
Voltage | 230 V |
