Festool MFT T-LOC Systainer Case
- Support work, drill and saw - a small portable workbench
- Systainer with special MDF work top
- Drilled to take MFT system accessories
- Fit an MFT clamp and secure your work
- MDF can be replaced if damaged
- T-LOC design can stack and clip to other Systainer cases
- 396mm long x 296mm wide
A great new addition to the Festool Systainer system, this case is fitted with a special MDF top that is especially drilled to take the Festool MFT System accessories. The MFT system work surface means that you can secure your work to the top using clamps, making it a very portable clamp system for when you are on the go. Being MDF also means even without clamps you can use the top of the box to support your work when cutting or drilling without damaging the box, as the MDF can be easily replaced.
As with all other Systainer cases, the main part of the case is made from a robust, plastic, able to lock with all other Systainers of the same size within the range using the T-LOC system incorporating the clever single T-LOC central control. This stands for Lock, Open and Control, giving three functions in one: twist to lock the lid shut, lock cases securely together in seconds, open any case whilst in the stack. Connects to other Festool Systainers, roll board and transporter (length 396mm x width 296mm). A roll board is also available to transport a stack of boxes easily.
