Festool TCT Saw Blade Fine 168mm x 1.8mm x 20mm 42T
- 1.8mm thin kerf saw blades for maximum performance
- Cut faster and achieve a perfect result
- Rapid cutting with exceptional clean finish
This high tech, high spec blade ensures the job gets done faster and with a better result. These new generation of thin kerf saw blades are designed to give maximum performance. The 1.8mm thin kerf saw blade and tooth geometry allows you to work faster, reduces the load on the machine.
The blade teeth are high-quality carbide resulting in a long service life. The tooth format is alternate bevel with a raker tooth (ATBR) producing rapid progress with a very clean finish.
These blades fit the Festool TS 60 plunge-cut saws.
