Festool TS 55-FEBQ Plus Plunge Saw
- Accurate plunge cutting saw for splinter free cuts
- 1.8mm thin kerf blade for fast cutting
- Fully compatible with Festool FS guide rail system
An unbeatable sawing system
With an innovative new cutting blade and the same reliability Festool customers have come to trust, the TS 55-FEQ/FEBQ coupled with Festool guide rails is an unbeatable sawing system.
Improved performance
Thanks to the new, thin 1.8mm kerf blade, less material is removed, allowing the saw to work faster. This coupled with increased speed and exceptional torque, the TS 55-FEQ/FEBQ Plus can run up to twice as fast as previous models.
Safe
The control electronics Festool have included with the TS 55-FEQ/FEBQ Plus ensure speed and temperature control, as well as a spring loaded guide wedge positioned in front of the blade to prevent jamming.
Angles
A full range of positions are available, including undercuts, from -1 to 47 degrees. You can be sure you are making accurate cuts every time, even on an angle.
Healthy
Efficient extraction when attached to Festool's adapted system using an extractor with Bluetooth remote control automatic switch, or with a dust bag.
Easy to use
Festool's FastFix system has been incorporated into the TS 55-FEQ/FEBQ Plus, ensuring blade changes can be completed in a few easy steps. Once the blade is changed, the sawing speed adapts to the material.
Extra features
The slimline housing allows cuts to be made up to just 12mm from the wall, making this tool even more versatile. The TS 55 FEQ Plus is also supplied in the new Festool T-LOC handy case.
Axminster Workshop Centrotec Compatible Depth Adjustable Bit HolderSpecial Price £3.98 £3.32 was £6.98 £5.82 Save £3.00 £2.50
Festool’s TS 55 saws have a reputation for absolute precision cuts, maximum power and extreme durability. This latest incarnation is no exception. The TS 55-FEBQ takes a 1.8mm kerf blade. The narrow kerf means it removes much less material, allowing the TS 55-FEBQ to cut at up to twice the speed of previous models. The new generation of cutting blades guarantees perfect cutting quality with maximum cutting performance.
A detachable splinter guard in front of the blade, gives a virtually splinter-free finish on both sides of the workpiece. Behind the blade a guide wedge acts as a riving knife and aids positioning the saw in an existing cut. The angle adjustment from -1° to 47° allows a slight undercut for perfect butt joints. In addition, the cut line remains the same no matter what the cutting angle. With the TS 55-FEBQ maximum cutting performance meets perfect cutting quality.
Optional guide rails, a wide variety of thin 1.8mm kerf saw blades and connection to an extraction system, form a first-class sawing system.
Supplied with 42 tooth thin kerf blade and Systainer SYS3 M 337 carry case.
N.B 230V version is known as model TS 55-FEBQ. 110V version is known as TS 55-FEQ.
Benefits
- Includes 36 month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft
- Original parts guaranteed
- 14 day money back
Bevel Angle Range | -1° to +47° |
Blade Diameter | 160 mm |
Bore Size | 20 mm |
Corded or Cordless | Corded |
Dust Extraction | 27 mm / 36 mm Outlet |
Max Depth of Cut @ 45º | 43 mm |
Max Depth of Cut @ 90º | 55 mm |
Motor Power | 1,200 W |
MPN | 230V - 576706, 110V - 576707 |
Nett Weight | 4.5 kg |
Rating | Trade/Professional |
Saw Blade Speed | 2,000 - 5,800 rpm |
Sound Power Level LwA [Uncertainty K] | 101 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 90 dB(A) [3.0 dB] |
Spindle Lock | Standard Feature |
