Fuji Spray 7002G M-Model Gravity Spray Gun
102588
From £254.58 £212.15
3 Reviews
Low Stock - Ready to dispatch
  • High build quality and high material quality
  • For serious hobby use or professional with occasional requirement
  • Gravity feed gun (7002G) with 400cc cup, lightweight and manoeuvrable
  • Supplied with an air cap set #3 (1.3mm) installed
Fuji Spray M-Model spray guns share the same high build and material quality as the Fuji professional T-series spray guns. The M-Model guns feature with the Fuji Spray Semi-PRO 2 stage spray system, designed for the serious hobby user or a professional with occasional requirement. The Fuji Spray M-Model has professional features such as a Fan Control Knob to adjust pattern size from small circular to wide (and all increments in between) and a Rear Pattern Control Knob. The Fuji Spray M-Model spray guns are “non-bleeder” style spray guns. The only time air comes out of the tip of the gun is when pulling the trigger. The spray guns boast an ergonomically designed insulated handle that is very comfortable in use and insulates well against the heat that can develop in the handle of HVLP spray guns after extended periods of use. This gravity feed gun (7002G) has a 400cc cup. Being lighter and more manoeuvrable, it is a good choice for smaller projects or cabinet interiors. Supplied with an air cap set #3 (1.3mm) installed. Please note, the parts for the M-Model spray guns are not compatible with other Fuji Spray Guns.
5.00 3
