Lamello Cabineo Cutter - 12mm
103950
From £276.28 £230.23
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • High quality industrial milling cutter
  • For CNC machines
  • Cuts perfect Cabineo recess
  • 12mm diameter
This is an industrial CNC milling cutter 12mm diameter. The CNC cutting of the recess for the Cabineo body can be done either from the top with a 15mm CNC drill bit or from the side using a CNC milling cutter.
Lamello produce the drill and a choice of cutters to suit the requirements of a variety of CNC machines. Fully dimensioned drawings are available for programming the CNC machine for each of the milling cutters and the drill option.
