Lamello Clamex P-14 Zeta Connector
From £107.88 £89.90
  • Unique fitting to overcome many design problems
  • Clamps, locking joint in place and is also detachable
  • No glue or screws are required, simple assembly
  • Only visible sign of joint is a single 6mm hole
  • Special ‘T’ slot needs to be cut by Lamello Zeta biscuit jointer
  • Joint angles 30° – 180°
  • Made from fibreglass reinforced plastic with zinc die-cast lever
  • Suitable for solid wood, composite boards and other sheet materials
Book your demonstration
Lamello products are renowned for their precision and quality, saving you time and money with outstanding results. Our knowledgeable and friendly team are available to demonstrate the Lamello range in person or via a video call. You can see the tools in use and ask questions before placing your order.
This is a truly amazing connector with a host of uses. Lamello has overcome many design assembly problems with this clamping connector; it is almost totally invisible, only a single 6mm hole shows. The Clamex P is a biscuit shaped fitting with a ‘T’ profile that slides in place, no screws or glue are needed. Having a pivot lever and two alignment studs, this lever is driven using a hexagon key though the 6mm hole, locking the fitting together forming a very secure joint. Ideally suitable for connections up to 45° in 18/19mm panels and for 90° connections in 16mm panels. The required slot is cut using a Lamello Zeta biscuit jointer specially developed for this application, cutting the slot and adding the ‘T’ to the bottom using a unique vertical mechanical drive. Made from fibreglass reinforced plastic, lever zinc die-cast for strength (tensile fitting strength 1000N = 100kg). Overall length is 66mm x width 27mm, each half has a depth of 14.5mm and it is 7mm in width (9.7mm o/a with ‘T’). Supplied as a pack of 80, 300 or 1000.
4.9 13
