For guaranteed perfect straight or angled cuts on site or in your home workshop, the MT 55 CC is the ideal machine.
Precise
Unrivalled cutting performance on or off the rail, the MT 55 CC executes accurate cuts every time. This is made possible by the tracking pointer, which moves with the blade tilt to allow you to see the exact cutting angle. An undercut facility is also available.
Versatile
Allowing you to make plunge, crosscuts, rip cuts and bevel cuts with ease, the MT 55 CC can be utilised for a multitude of different tasks whether you are on site or in a home workshop.
Variable speed
Thanks to the CUprex-Compact motor featured in the MT 55 CC, you can select your cutting speed and therefore tackle a wide range of different materials and thicknesses.
Easy
The MT 55 CC is easy to set up, accurate and reliable. A welcome addition to your toolkit, you won’t be disappointed with this saw!
This Saw, Guide Rail and Angle Fence kit combine to give you the potential to make perfectly accurate straight cuts at angles of ±45° and up to 2.4m long. The angle fence attaches to the guide rails with the joining bar. Use the large legible scale to set the angle required.
The MT 55 cc excels as a plunge cutting circular saw whether on or off a guide rail. The powerful CUprex-Compact motor and continuously variable speed allows for a variety of blade options for cutting different thickness and different materials. Blade changes on the MT 55 cc are fast and simple. This all-round machine has some unique features; a tracking pointer moves when tilting the blade to indicate the exact position of the cut line at any angle. The scoring function enables you to produce a perfect finish in any material. A -1° undercut facility is great for perfect butt joints (the full tilt range is -1° to +48°). The well positioned depth stop is fully adjustable to within a millimetre and adjustable for blade wear after sharpening. Everything a plunge saw should be.
The MT55 saw is supplied with 48T saw blade and Mafell T-MAX case, kit comprises; 1 bag, 1x 1600mm guide rail, 1x 800mm guide rail, 1x rail joiner, 1x bevel and a pair of quick clamps
