Mirka DEROS II 5650CV Random Orbit Sander
111675
From £546.98 £455.82
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Unique 400W brushless high performance motor is very compact
  • 5mm orbit for fast material removal
  • LED speed indicators to easily adjust variable sanding speed
  • Low profile with low weight, use in any position
  • Use with either 125mm or 150mm pad - comes with both
  • Soft start and electronic brake pad for controlled sanding
  • Features an integrated vibration sensor and Bluetooth low energy technology
  • Backing pads have multi-hole design to move dust effectively
  • 2+1 Extended Warranty on sanders, registration required
The DEROS II has to be the most compact random orbit sander on the market today. This model 650CV is supplied with both 125mm and 150mm pads that can be simply swapped over. The body of the machine houses a unique 400W brushless motor with motor control technology. With its small body and low weight of just 1kg, it is perfect for all prolonged use in almost any position - flat, overhead or vertical. The brushless electric motor is smooth running and has a low noise level, particularly helpful for when sanding for longer periods.
The sander features upgraded power compared to previous models for even greater service life; the body of machine houses a 400W high performance, smooth running brushless motor and maintains constant speed even under load. It is perfect for heavy applications and demanding jobs. The DEROS II 5650CV is fitted with a soft start and electronic brake. The sanding speed is adjustable, with the range covering 4,000 - 10,000 rpm. The updated design makes it easy for the operator to change; LED indicators are located on the speed selector, together with a separate on/off switch and lockable speed for optimum control. The DEROS II also features a closed construction so that no dust can enter the machine causing wear. The power cord is exchangeable.
Mirka Abranet® is recommended for use with the machine to produce a flawless finish for a huge range of sanding applications. The 125mm and 150mm backing pads can be exchanged quickly to suit your application; both pads have a universal hole pattern to enable the fitting of many different makes and types of abrasive disc. One of the key features of the Mirka DEROS II is the Bluetooth technology, which helps monitor your exposure to vibration. Simply access the myMirka app through Bluetooth connectivity.
Supplied with 125mm and 150mm pads, 5 x 125mm and 5 x 150mm Abranet® discs mixed grits, pad savers and T-LOC storage case.
2+1 Extended Warranty on Mirka sanders, registration required within 30 days.
Warranty Mirka 3 Year Warranty (Registration Required)
Registration is required within 30 days of purchase.
The Mirka 2+1 year warranty applies to Mirka sanders, dust extractors and polishers. If a problem occurs with a Mirka tool caused by a manufacturing defect material or by workmanship; Mirka will repair your tool free of charge in accordance with the warranty terms.
Registration is required within 30 days of purchase. More information can be found on the Mirka warranty website and in the warranty conditions.
For warranty issues outside of the UK, tools must be returned to the UK and carriage charges would be at the customer's own cost.
Register your product now
