PROXXON KS 230 Saw
PROXXON KS 230 Saw
- 8mm depth of cut
- 58 x 10mm saw blade
- Fully machined aluminium table
- Sturdy ABS base
- Mitre fence and rip fence
- 34mm diameter dust extraction port
PROXXON Solid Carbide Saw Blade for KS230E - 50mm x 0.5mm x 10mmFrom £41.48 £34.57
PROXXON Super-Cut Blade for KS230E - 58mm x 0.5mm x 10mm 80TFrom £12.18 £10.15
PROXXON Diamond Coated Saw Blade for KS 230E - 50mm x 0.5mm x 10mmFrom £17.38 £14.48
A small precise mains driven modelling saw
For cutting a range of materials, a variety of blades are also available
Super-Cut Crosscut Blade
58mm diameter (10mm bore). 80 alternately set teeth. Ideal for hard and soft wood as well as plastic and Pertinax. Teeth are individually set and sharpened for superior cutting power! Supplied with the saw. View blade
Fine Blade
50mm diameter (10mm bore), 0.5mm thick. Designed with fine teeth for precision cutting in non-ferrous metals (aluminium, brass, copper). Also suitable for cutting compound materials like PC cards, and sawing wood and plastics. View blade
Solid Carbide Blade
50mm diameter (10mm bore). 0.5mm thick. Also fine-toothed, ideal for cutting fibreglass sheets up to 3mm, non-ferrous metals, duro-plastics and other 'difficult' materials. View blade
Tungsten Carbide Tipped Blade
50mm diameter (10 mm bore), 1.1mm thick. 20 TCT teeth for extremely clean cuts of balsa, plywood. Can also be used for cutting PC cards and Polycarbonate.View blade
A small precise mains driven modelling saw with an 8mm depth of cut using the standard 58mm diameter blade. It has a fully machined aluminium table top some 160 x 160mm mounted on a sturdy ABS base, and comes with a mitre fence and rip fence. There are 2 blades available for different materials, the 300108 alternating set for wood and plastics and the 300109 for fine cuts. There is a 34mm diameter dust extraction port at the rear of the machine.
Blade Diameter | 58 mm |
Bore Size | 10 mm |
Dust Extraction Outlet | 34 mm |
EAN Barcode | 4006274270060 |
Max Depth of Cut @ 90º | 8 mm |
Model | KS 230E |
Motor Power | 85 W |
Nett Weight | 1.8 kg |
Rating | Home/Light Trade |
Saw Blade Speed | 5,000 rpm |
Table Size | 160 mm x 160 mm |
Voltage | 230 V |
