PROXXON MICROMOT 230/E Mill/Drill
- Slim, easily handled and light weight (270g)
- Variable speed with feedback
- Special balanced, low noise DC motor
- Supplied with 6 collets
Perfectly precise with PROXXON - The 20mm Collar System
The 20mm collar range of PROXXON tools allows you to easily connect to one another and achieve maximum precision and versatility with your intricate tasks. Simply clamp the collar of your PROXXON drill or grinder to the drill stand, universal holder or router base and your tool is held steady whilst allowing you to take on a range of tasks including routing, engraving and drilling.
The MICROMOT 230/E is designed for drilling, milling, grinding, polishing, brushing, cutting and engraving. The extremely slim housing of glass-fibre reinforced POLYAMIDE with a soft component grip area enables the unit to be handled with two fingers (pen grip). The maximum speed of 21,500rpm can be continuously reduced to 6,500rpm through full-wave electronics. This tool offers nearly the same torque in the lower speed range. This is especially important for micro-drilling, brushing and polishing. It has a continuous run time of 5-minutes at full speed, allow 10-minutes rest before continuing. Ground, ball-bearing spindle. High quality MICROMOT steel collets.
Corded or Cordless | Corded |
EAN Barcode | 4006274284401 |
Model | 230/E |
Nett Weight | 0.27 kg |
Voltage | 230 V |
