PROXXON MSG Motorised Carver
702047
From £123.98 £103.32
  4. Half Star
8 Reviews
In Stock - Ready to dispatch
  • For model makers and woodcarvers
  • Special balanced, low noise DC motor
  • Includes 3 Japanese bi-metal blades
  • Supplied in case
The MSG Carver is designed for woodcarvers and model makers. Its main uses include the carving of all types of wood, the restoration of furniture and antiques, lino cuts and precision paint removal and it is also possible to carve plaster.
The MSG features a special balanced, low noise 50W DC motor with extremely high life expectancy and a gear head made of die-cast aluminium. The unit is not designed for heavy usage, let the blade do the work. The main housing is made of glass fibre reinforced polyamide iis only 230mm long. Optional accessories include a set of 5 chisels (2 gouges, Vee tool, chisel and curved tip chisel) and a profiled sharpening stone.
The MSG is supplied in a carry case along with 3 high-grade bi-metal Japanese blades (gouge, Vee tool and chisel).
Supplied in a carry case along with three high-grade bi-metal Japanese blades (gouge, vee tool and chisel).
3.30 8
