TSO Products GRS-16 Guide Rail Square
- Fits onto either Festool, Makita or Triton guide rails
- Perfectly balanced with no need for counter balancing supports
- Easy to use and extremely accurate, American made
- Solid aluminium, anodised for durability
- Connection to track takes a mere 5 seconds
- 385mm long reference edge at precisely 90° to the track
- Notched front edge allows the use of a guide rail clamp
- Unparalleled for speed, accuracy, and ease of use
Axminster Professional Quick Lever Guide Rail Clamp 160 x 60mmFrom £22.48 £18.73
Axminster Professional Stainless Steel Metric Rule - 300mmFrom £8.28 £6.90
This is a solid piece of CNC machined aluminium, high quality, highly durable and extremely accurate.
The GRS-16 guide rail square fits onto either Festool or Makita guide rails. Its beauty lies in its simplicity; connection to your track takes a mere 5 seconds. There are no loose fixings or loose parts to get lost. The GRS-16 is self-aligning, simply slide it into the T-slot on the underside of you track and then close the latch. The latch locks firmly, ensuring the 400mm long reference edge is at precisely 90° to your track. There is a small notch in the front of the reference edge to allow you to use a guide rail clamp for extra security should you so wish. Once fitted this guide rail square allows you to set your guide rail at a perfect 90°, in an instant, every time.
The speed, accuracy and the ease of use this guide rail square is well worth the investment.
