UJK Cam Lock Hold Down Clamp M6 (Pair)
- Strong anodised aluminium levers
- M6 x 75mm tee-bolts
- Easy to use, self-locking, quick-release
- High clamping force; holds tight
- Excellent accessories for jig making
- Supplied as a pack of 2
Axminster Professional Quick Lever Guide Rail Clamp 160 x 60mmFrom £22.48 £18.73
Supplied in packs of two, the UJK Cam Lock Hold-Down Clamp offers ultra fast locking and quick release for all manner of fixtures and fences. They are easy to use, self-locking and exert plenty of force. These come with M6 x 75mm, tee-bolts; by substituting the tee-bolts for regular M6 bolts you have the option of using the Cam Lock wherever you wish.
Screw the lever down until it is touching the top of the fixture/fence etc. Pushing the end of the lever down, applies considerable clamping force. To release the fixture, simply lift the lever.
Each pack contains two anodised aluminium cam levers, two threaded cross dowels, aluminium stepped track adaptor and nylon and steel washers.
EAN Barcode | 5052511117284 |
