UJK Universal Dovetail Jig
Cosmetically imperfect products, unused returned items or refurbished 'as good as new' products, at a discounted rate. Our quality assurance checks are very high and occasionally, cosmetic imperfections happen. In our continuing efforts to becoming more sustainable, we're offering ‘as good as new’ products, at a discounted rate. Same quality of product at exceptional value. Show More
Only left in stock
- Produce 6 different highly accurate joints from day one
- UK made jig, includes 3 Axcaliber cutters and 2 threaded guide bushes
- Efficient and effective dust extraction outlet
Flying the flag for British Made tools
Straight out of the box, the UJK Universal Dovetail Jig gives you the possibility of producing six different joints, with unrivalled accuracy!
Six joints, unrivalled accuracy
Dovetails make very strong joints. However, the method of keying pieces of timber together by engaging tapered pins or tails into corresponding sockets can be a very time consuming task when done by hand. Plus, there's now a quicker and more efficient way to produce such joints thanks to the UJK Universal Dovetail Jig, which allows simple, quick and accurate joints with a router.
Half Blind Dovetail
Used primarily for drawer box construction, half blind dovetails show the pins and tails on one side of the joint, while remaining completely invisible on the other. This makes them ideal for fastening drawer fronts to drawer sides.
Sliding Dovetail
Frequently used in case work to connect shelves to side walls or between shelves in drawer dividers, sliding dovetails are deceptively simple joints to make using this jig.
Through Dovetail
As one of the strongest joints available, the through dovetail has many benefits. These include being aesthetically pleasing thanks to its interlocking capabilities and resistance to being pulled apart. Furthermore, it offers a large gluing area, however the joint will also hold together even without glue!
Box/Finger
Ideal for making boxes and other solid cube shapes such as chests and carcases, precise comb or finger joints offer castellations with a very long glue line.
Groove/Housing
Useful for adding partitions into cabinets and bookcases, a groove/housing joint is a strong and reliable joint that's simple to make. A trench is cut into which the end of another component is inserted.
Corner Dovetail Rebates
Simple to construct, corner dovetail rebates enable mating parts to align easily and accurately. Furthermore, they create a larger gluing surface which provides a greater load-bearing capability than standard butt joints.
British Made
With a focus on British manufacturing, the vast majority of UJK products - including this jig (the first of its kind) - are proudly designed, developed and made here in Axminster, UK. The ever-growing range of unique products offer what woodworkers want and need.
Explore the full range...
Features and benefits
What's more, there's a host of other benefits which will allow you to work more efficiently. This will save you both time and effort while you work!
No course required
Unlike other more complicated dovetail and jointing jigs, the UJK Universal Dovetail Jig is simple to set up and use. It comes complete with an instruction manual, plus there's several helpful videos available online for quick set up.
Accuracy and strength combined
The base of this jig is a heavy gauge steel pressing with other parts precisely CNC machined. Furthermore, the super hard anodised finish on the finger templates ensure long term accuracy.
Excellent dust extraction outlet
Held in place by a strong magnetic strip, the greatly improved dust extraction outlet is easily detached when loading workpieces in your jig.
Greater surface area
The jig features a stabiliser bar located in front of the comb, which provides a much greater surface area to support your router's base.
UJK Guide Bush Adaptor for Elu, DeWALT, CMT2000, Trend, RyobiFrom £9.98 £8.32
UJK are proud to introduce the Universal Dovetail Jig; made and developed in the UK. Straight out of the box it gives you the possibility of producing six different joints, with unrivalled accuracy.
UJK Universal Dovetail Jig can produce:
1. Half blind dovetails
2. Box/ finger joints
3. Through dovetails
4. Sliding dovetails
5. Groove/ housing joints
6. Corner dovetail rebates
The base of this jig is a heavy gauge steel pressing with other parts precisely CNC machined; a combination of accuracy and strength. The super hard anodised finish on the finger templates ensure long term accuracy. The jig features a stabiliser bar located in front of the comb, which provides a much greater surface area to support your router’s base.
The UJK Universal Dovetail Jig also incorporates a greatly improved dust extraction outlet. Held in place by a strong magnetic strip, the outlet is easily detached when loading workpieces in your jig.
Set-up and use is simple. An 11mm offset at each end of the template greatly speeds up initial marking. Fast cam action clamps, hold your workpieces quickly and securely.
The jig can be used with any router that will take 1/4", 8mm or 1/2" shank cutters. The jig comes with three 1/4" shank Axcaliber precision ground TCT router cutters; A matched pair for dovetailing (7 degree dovetail and straight) and a 12.5mm straight cutter. Also included are two American style threaded guide bushes and full instructions.
Material capacity: 300mm width, 6–25mm dovetail thickness.
An additional Leigh guide bush adaptor to suit your router should be purchased separately. An 8mm- 1/4" sleeve is also supplied.
EAN Barcode | 5052511120987 |
Material Thickness | 6 mm to 25 mm |
Material Width | 300 mm |
Rating | Trade/Professional |
