Woodcut Tools Bowlsaver Max 4
108929
From £769.98 £641.65
  5. Half Star
2 Reviews
Low Stock
  • Produce up to 4 bowls from a single blank
  • Core bowl from 75mm to 430mm diameter
  • Blades with tough, long lasting Stellite tips
  • 510mm long handle with foam grip for control
  • Large main platform main provides solid support
  • 2MT Tailstock mount with drawbar for additional stability
  • Easy to follow user guide with planning templates
  • Tool post to fit lathe required (available separately)
Safe, solid and simple to use
Quadruple the amount of bowls you produce from one blank with Woodcut Tools Max4 Bowl Coring System.
Long lasting blades
Supplied with three heavy duty, zinc coated blades. Each blade is shaped to a radius and supplied with a precision sharpened Stellite cutter that are proven to be long lasting and hard wearing.
Withstand any wood
Bowl coring will apply pressure to the platform, especially if the wood is hard and dense. The Max4 is therefore made from precision machined cast aluminum and steel that is anodised to last and support turners to successfully core bowls small or large, wet or dry.
Stay stable
A 2MT Tailstock mount is supplied to enable integration of the Max4 product with the lathe tail stock and therefore ensures a stable bowl coring platform.
Ultimate control
The 510mm long handle with a foam grip gives you the leverage to operate the Bowlsaver Max4 and stay in control. The end of the handle features a spigot to fit an additional handle if further leverage is required.
Complete versatility
A simple adjustment of the tail stock slide on the platform will support the turner to core the shape of the bowl they require.
Start coring bowls today
Supplied with a detailed guide and ready to use, planning templates to successfully core a nest of bowls straight away.
Watch Woodcut Tools’ Dan Hewitt and Colwin Way discuss the Max4 Bowl Coring System.
Turning a bowl from a large blank presents the turner with some interesting issues. Not least the amount of useful timber wasted in the form of shavings when hollowing the interior.
The Woodcut Tools Bowlsaver Max 4 enables you to produce more than just one bowl from a single large blank. The Woodcut Tools Bowlsaver Max 4, comes with 3 blades. Thus from a single blank you have the potential to create up to four bowls, hence the name; Max 4.
What may at first sight look complicated is in fact quite simple to use. The unique design offers easy adjustment in order to core a range of bowl shapes and sizes. With the Woodcut Tools Bowlsaver Max 4 you can core bowls from 75mm up to 430mm diameter.
The main platform is cast and precision machined anodised aluminium and steel. It is designed to successfully cope with the pressures of the coring process whether small or large, bowls, wet or dry wood. A suitable tool post to fit your lathe is required for the platform.
The Max 4 comes with a 2MT Tailstock mount, which provides additional stability. A 3/8"x 405mm threaded rod is supplied as a drawbar to provide integrated extra support and stability from the tailstock.
The blades are Stellite tipped. Stellite has great wear and shock resistance. Stellite is used to tip large industrial bandsaw blades, proven to be long lasting and hard wearing. The tips are easily sharpened with a diamond hone.
The large knife has additional support from a machined steel post and a bearing in order to minimise movement especially when coring hard, dense wood.
The 510mm long steel handle with a foam grip offers maximum control. The end of the handle features a spigot to fit an additional handle if further leverage is required.
The Woodcut Tools Bowlsaver Max 4 includes everything you need to start coring bowls from 75mm up to 430mm in diameter. It comes with a detailed guide and ready to use, planning templates to successfully core a nest of bowls straight away.
All packed in a large foam lined box, providing convenient storage when not in use.
​Dimensions (approximate)
Base platform footprint: 248mm long (measured from the front edge of the base plate to tailstock assembly x 210mm wide
Weight: 9kg
Operating requirements: minimum 1.5kW flatbed lathe with 405mm to 635mm swing.
N.B. You will need to choose the correct diameter tool post to suit your lathe from those listed (sold separately).
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.50 2
