Woodcut Tools Pro-Mount Bench Stand
- Versatile carving stand with independent locking levers
- Use with the Woodcut Tools Pro-Mount Body & Tool Post
- Sturdy base enables you to work on bench, table or any fixed surface
- Full 360° horizontal rotation; full 360° vertical rotation
- Sturdy platform and easily adjustable; work in comfort
The Woodcut Tools Bench Stand is to be used with the Woodcut Pro-Mount Body & Tool Post and allows the stand to fix securely to a work bench, table or other fixed surfaces. Designed with slots in the base, the bench stand can also be mounted on a milling machine cross slide or pillar drill table. The Pro-Mount system by Woodcut Tools will prevent any wobbling or movement while carrying out work on freshly turned pieces or carving. Ensuring precision in your finished piece and also safety when you work, particularly when used for carving.
