Axcaliber Bearing Guided Cove Cutters
From £28.38 £23.65
  • Bearing ensures consistent profile
  • Use with matching rounding over to produce a rule joint
  • Make trim moulding from specific timber
  • Precision made on multi axis CNC machines
  • High shear-cut angle for cleaner finish
  • Thick PTFE coating helps cutter to remain free of resin
  • Available in 1/4"(6.35mm) or 1/2"(12.7mm) shanks
  • 12.7mm radius
Assurance with Axcaliber
- see how they're made
Next to straight cutters, Cove cutters are amongst the most common in use. This particular size has a number of applications. Not just for creating a decorative edge. In conjunction with a matching rounding over cutter, you can produce a rule joint for a drop leaf table. By routing, the edge of a board and then cutting it off on a saw bench you can make lengths of trim for edging laminate floors in a specific timber.
The bearing allows this cutter to produce a moulding around a curved edge. The bearing ensures that the moulding is of consistent depth in relation to the edge. There is no need to use a side fence, making setup easier and quicker. Use of a bearing guided cutter avoids situations where the fence may become an obstruction. Unlike a guide pin, the bearing will not leave a scorch mark.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up. 12.7mm radius.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.40 5
