Axcaliber Flush Trim Cutters Bottom Bearing
AX803281
AX803281
- Perfect for flush trimming of laminates
- Most useful for template routing
- Precision made on multi axis CNC machines
- Gives a very clean smooth cut
- PTFE coating helps minimise resin build-up
Show more
Show less
A range of cutters in both 1/4"(6.35mm) and 1/2"(12.7mm) shank sizes which are excellent for the flush trimming of laminates and template type routing operations.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
