Axminster Woodturning Button Jaws - 150mm
101724
From £82.78 £68.98
50 Reviews
In Stock - Ready to dispatch
  • Recommended for SK88, SK100 and SK114 chucks
  • Perfect reverse chucking solution
  • Conical rubber buttons hold work gently and securely
  • Grips both externally and internally
  • Tapped holes for wide variety of diameters
  • Can be configured to hold odd shaped workpieces
  • Jaws supplied with complete with rubber buttons
  • Made exclusively by Axminster in Axminster
  • Made from lightweight aluminium
At 150mm diameter, these jaws allow you to reverse chuck smaller workpieces quickly and securely at the turn of a chuck key. The conical rubber buttons pull your work gently back against the aluminium jaw plates without damaging its edge. You can use them externally or internally. A series of tapped holes offers you a variety of diameters. It is also possible to grip odd shaped pieces using different holes. The jaws come with rubber buttons. They will fit the SK88, SK100 or SK114 chucks. As an alternative to using the buttons, stacking turn studs are available as an optional extra. They form an excellent primary holding method for all manner of round or square blanks and, give a very secure grip. The studs can be used singly or doubled up using the longer bolts supplied. Recommended maximum speed 1,500rpm. These jaws are made from aluminium making them lightweight. As with all our dovetail jaws they simply bolt onto the Accessory Mounting Jaws.
British Made British Made
4.80 50
