Clear Lightweight PVC Extraction Hose
AX22321
AX22321
- Lightweight, double ply PVC wall, encapsulating a spring steel wire helix
- Extremely flexible, can be used where tight curves are required
- Blockages can be easily seen, enhancing the systems performance
- Clockwise spiral
Axminster Workshop Quick Release 63mm Hose Fixing Clip (Pkt 2)From £6.98 £5.82
Show more
Show less
Lightweight, double ply PVC wall, encapsulating a spring steel wire helix. Extremely flexible, can be used where tight curves are required. Blockages can be easily seen, enhancing the systems performance. Clockwise spiral. Made in Germany.
