Axminster Model Engineer Series Top Slide for C0 Micro Lathe
- Rotatable Top Slide replaces the standard tool holder
- Angle movement ± 30°
- 40mnm travel, takes 8mm shank tooling
- Tungsten steel for a long service life
- Overall size 100mm x 49mm x 58mm
Axminster Engineer Series 11 Piece Tungsten Carbide Lathe Tool SetFrom £27.48 £22.90
Axminster Model Engineer Series Auto Feeder for C0 Micro LatheFrom £57.28 £47.73
The C0 Rotatable Top Slide replaces the standard tool holder supplied with your lathe. The Slide can be set to an angle of up to ±30°. It has a travel of 40mm and takes 8mm shank tooling. Made from Tungsten steel for a long service life. Overall size: 100mm x 49mm x 58mm.
Fits Axminster Model Engineer Series C0 Micro Lathe and SIEG C0 lathes.
EAN Barcode | 5052511130597 |
