Axminster Professional AP2260BS2 Belt Sander - 230V
107708
From £959.98 £799.98
  5. Half Star
10 Reviews
In Stock - Ready to dispatch
  • Sands either vertically, horizontally or any angle between
  • Sanding belt oscillates for a scratch-free finish and longer abrasive life
  • Table height adjustment by geared handwheel for precision setting
Smooth running, quiet and very useful!
If you're looking for a robust, well made and hassle-free machine, this belt sander has got to be one of the most useful machines to have in any woodworking workshop.
Achieve professional results
The sanding belt oscillates for a scratch-free finish and longer abrasive life.
Easy to use
With rack & pinion table adjustment, it is quick and easy to move the table to where you need it.
Sand at any angle
Whether you need to sand vertically, horizontally or any angle in between, this belt sander is the perfect choice!
Need to carry out curved work?
Thanks to the small sanding table, curved work is a breeze.
3 Year Guarantee
For complete peace of mind, we cover all parts and labour free of charge for three years.
This compact belt sander is a well made and relatively simple machine. With a 2.2kW motor driving a 150mm wide belt, it is one of the most useful machines to have in any woodworking workshop. The belt drive has an automatic oscillating action to provide a scratch-free finish and longer abrasive life. The belt also runs on a graphite anti-friction plate. The whole belt platen can tilt through 90° from vertical to horizontal, the precision ground cast iron table being easily adjusted in two planes to suit. The table has a stanadard 3/4" x 3/8" mitre slot to take a mitre fence. The dust hood can be rotated to clear the end of the belt for easy belt changing, and also to allow a small table to be mounted for sanding curved work. The stand is made from thick gauge welded steel and had a very useful belt storage cupboard. Smooth running, quiet in use, a very useful finishing machine. Supplied with a 150mm x 2,260mm 80G abrasive belt fitted.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Machine Classification
4.60 10
