Axminster Professional SD410T Thicknesser 415V 3ph
- Heavy duty thicknesser providing an ultra smooth finish
- Features a spiral cutter block
- Cast iron and steel construction ensures stability
- Column supported table for consistent thicknessing
- Digital gauge allows fast, precise adjustments
- Includes a table extension to support large boards
TC Spiral Cutters for Professional Planers - 15 x 15 x 2.5mmFrom £44.98 £37.48 -
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)From £18.28 £15.23
The Axminster Professional SD410T Thicknesser delivers outstanding precision and consistency, making it an excellent choice for demanding thicknessing work. Its 97mm spiral cutting block houses 72 knives, producing an exceptionally smooth finish while offering a significantly longer service life than traditional HSS blades. When an edge eventually dulls, simply rotate the cutter insert 90° using the supplied Torx driver - tighten, and you’re straight back to work. There’s no resetting, no downtime, and no waiting for blades to be sharpened. Spiral cutterblocks also run more quietly and with far less vibration.
Built from heavy-duty cast iron and steel, the SD410T Thicknesser provides long-term stability and vibration-free operation. The column-supported table ensures consistent accuracy, while the digital gauge allows fast, precise adjustments.
Driven by a powerful 4kW motor, the cutterblock runs at 4,200rpm and feeds material at 6.5m/min for a clean, refined finish. Designed to handle large workpieces with ease, the machine includes a 348mm rear extension table for added support. With a maximum planing width of 410mm and a maximum depth of cut of 5mm, it has the capacity to remove stock efficiently and reliably.
Dust extraction is handled through a 120mm outlet that can be positioned on either the left or right, offering flexibility in tight workshop layouts. An airflow of 1,800 m³/h is required to maintain a clean, safe workspace. The machine operates on 400V.
Axminster Professional 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classification
These products are designed for frequent and extended use in professional environments, offering the performance and durability required for trade and workshop applications, without being intended for full scale professional or continuous use. They must be maintained and serviced annually. Guarantee is void when used for industrial use or part of a production line.
Learn more| Cutterblock Diameter | 97 mm |
| Cutterblock Speed | 4,200 rpm |
| Dust Extraction Outlet | 120 mm |
| EAN Barcode | 5052511142507 |
| Feed Speed | 6.5 m/min |
| Knives | TC Spur Cutters x 72 |
| Length of Table | 750 mm |
| Max Depth of Cut Thicknesser | 5.0 mm |
| Max Thicknessing Height | 220 mm |
| Min Extraction Airflow Required | 1,800 m³/hr |
| Model | SD410T |
| Nett Weight | 306 kg |
| Overall L x W x H | 900 x 700 x 954 mm |
| Plug Fitted | UK 16A Plug |
| Power | 4.0 kW |
| Rating | Frequent Use |
| Sound Power Level LwA [Uncertainty K] | 90 dB(A) |
| Sound Pressure Level LpA [Uncertainty K] | 100 dB(A) |
| Table Size | 750 x 408 mm |
| Voltage | 415 V |
International delivery is unavailable for this product.
