Perfect for constructing or extending your bespoke workshop extraction system, the Axminster Trade 100mm Steel Duct Kit reduces static discharge and provides an airflow with virtually no drag and resistance. Taking these factors into consideration, the all metal system spiral ducting reduces the risk of fire for complete peace of mind.
Lightweight and Cost Effective
Spiral duct pipes can span longer distances in your workshop with minimal support. This saves you money as there’s less accessories required.
Strong and Durable
Galvanised steel ducts have the quality of sturdiness and strength, thanks to their rigid structure. This means that they will not suffer damages during installation or assembly.
Protective Coating
Highest quality galvanised steel which prevents rust from forming. This allows the ducting to be installed outside as well as inside for complete flexibility.
Minimal Maintenance
Galvanised steel has extreme longevity; more than that of many other alloys. As such, this galvanised spiral duct system can be used over a long period of time.
Use this Galvanised Steel Spiral Ducting kit to construct or extend your workshop extraction system. This kit comprises eight 1.5m lengths of steel ducting plus a variety of bends, branches and fittings. This kit provides a practical, functional and cost effective solution to creating your own bespoke extraction system.
Rigid spiral ducting provides far superior airflow compared to flexible hose. In addition to being stronger, it minimises static discharge and it looks good. Quick and easy to install, the pipe can be cut with a thin disc on an angle grinder. Use the blast gates and a short length of flexible hose to connect the system to individual machines.
