Initially intended for use with sash clamps, T-bar clamps, clamp heads and pipe clamps, there is no reason why these can't be used with virtually any clamp with bare steel or iron jaw faces. A small but powerful magnet embedded in the material keeps the pad in position while you load and tighten the clamps.
Sold individually, each pad is 6mm thick by 50mm square. Made from a resilient, non-marring material, these pads allow full use of the clamps without leaving marks or bruises on your work.
