Axminster Professional Twist & Fix 100mm Stitched Polishing Mop
105422
105422
From £10.58 £8.82
  5. Half Star
9 Reviews
In Stock - Ready to dispatch
  • Stitched to give a firmer working surface
  • Second stage polishing steel, stainless steel and iron
  • Mounts directly onto the Ultimate Edge Twist & Fix arbor
  • Recommended for use with pink or white compound
These 100mm diameter stitched sisal mops have leather centre washers and 12mm bore for mounting onto the Ultimate Edge Twist & Fix arbor.
Stitching produces a mop with a firmer face; a stitched mop's normal usage is in the first and second (if required) stages of the polishing process. For best results use a separate mop for each different compound, mark each mop using a felt tip pen with the type of compound used. Good results obtained with pink or white compound.
Sold in pairs, both need to be used together when used with the Twist & Fix arbour.
British Made British Made
4.70 9
