Axminster Woodturning Turner's Calipers
AX29722
AX29722
- Available in large or small to cover most measuring situations
- Each set contains one double ended pair and an inside/outside pair
Axminster Workshop Centrotec Compatible Depth Adjustable Bit HolderSpecial Price £3.98 £3.32 was £6.98 £5.82 Save £3.00 £2.50
Show more
Show less
Two sets of turner's calipers, large or small, which between them should be able to cover most measuring situations. Each set contains one double ended pair for measuring wall thicknesses (type 1) and an inside/outside pair for checking diameters (type 2). In both cases the two ends of the calipers produce the same setting, allowing measurements to be made without removing the calipers from the work.
Capacities are: Small Set - type 1: 120mm, type 2: 190mm. Large Set - type 1: 220mm, type 2: 260mm
#AxminsterTools
