This Axminster Workshop Belt & Disc Sander enables shaping, sanding and profiling to be carried out easily and safely on wood.
High levels of dust extraction
The belt is fitted with close fitting guarding, to help with efficient extraction for safeguarding health and better visibility while working. Plus, almost 100% dust extraction can be achieved when connected to a simple vacuum extractor.
Compounds and mitres
The table incorporates a mitre fence running in a slot, for bevel and compound angle sanding. Both sanding functions use a decent size work table which pivots from 0° to 45°. Additionally, the sanding platter moves from vertical to horizontal without hassle.
Strong, robust construction
A heavily constructed chassis is constructed in a single iron casting; this supports the belt arm and tables. There are also locating holes for securing the sander to a workbench, if desired.
Hook and loop
Sanding discs are easily interchangeable, thanks to the hook and loop attachment.
Multi belt position
The belt sanding platen can be positioned vertically or horizontally.
Compact design
The compact design enables you to store the machine under your bench when it is not in use. Perfect for the smaller workshop.
3 Year Guarantee
For complete peace of mind, we cover all parts and labour free of charge for three years.
This compact and neatly designed sander features a 100mm belt and a 150mm disc. It comes with a good sized worktable, which can be used with either function. The table tilts up to 45° and the mitre fence allows bevel and compound angle sanding. The belt sanding platen can be used vertically or horizontally. The machine has close fitting guarding with a 63mm extraction outlet. Connection to a suitable vacuum extractor offers almost total dust extraction. The main body is a single iron casting for strength and stability and has locating holes for securing the sander to a workbench.
This sander will be a welcome addition to many small home workshops, enabling shaping, sanding and profiling to be carried out easily and safely. There is a wide selection of abrasive belts and discs available, the discs are of the hook and loop type for easy changing.
Please note these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.
Compact, neatly designed 100mm belt and 150mm disc sander
Tilting table with mitre fence for sanding compound angles
Close fitting guarding helps achieve high level of extraction
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee may be void when used for business or educational purposes.
