The AW2260S is a substantial planer/thicknesser with spiral cutter block capacity. This machine would be at home in any home workshop or small trade workshop.
Buy with confidence
So sure are we of the quality of this Planer Thicknesser, we cover all parts and labour free of charge for three years! Find out more
Spiral Cutter Block
Spiral cutters produce an incredibly smooth finish. They last many times longer than HSS blades and are noticeably quieter in use.
Single Lift Tables
The tables are joined together and can be lifted in one motion, making it quicker to switch between jointing and thicknessing.
Digital Height Readout
Quick and easy thickness adjustment ensures accurate cuts, every time.
1500W Motor
Ample power, yet still runs on a normal 13 amp plug.
Alloy Fence
A tilting alloy fence with a sturdy cast iron support arm provides accuracy and durability.
Great Capacity
The AW2260S has a maximum cutting width of 250mm and height of 180mm, allowing you to tackle big home projects.
The AW2260S planer thicknesser with its spiral cutter block is a pleasure to use and delivers excellent results. The spiral cutting block has twenty four, four sided, solid carbide cutters arranged in a helix. The shear cutting action produces a silky smooth finish. There is a complete lack of planing ripple as often found using traditional straight knives. Each cutter’s edge will last around 10-20 times longer than a HSS knife and each cutter has four edges. When a cutter does become dull, take the torx driver supplied and turn the cutter through 90°, retighten the screw and you're ready to go again. Down time is a bare minimum, no resetting or waiting for the blades to come back from the sharpening. Spiral cutter blocks are notably quieter in use and produce noticeably less vibration. Extraction is more efficient due to the size and even shape of the waste produced.
When surface planing, a long rigid alloy fence supports your work. The fence is easily adjustable with stops for 90° and 45°. Changing from surfacing to thicknessing is very simple. You don’t need to remove or change the position of the fence when you lift the table. The single lift table mechanism works well, spring supported it requires little effort. There is a power feed engagement lever for use when thicknessing; the 4.8m/min feed speed ensures a smooth, even finish. The AW2260S is fitted with a digital thicknessing gauge, greatly simplifying depth adjustment.
Substantial planer/thicknesser with spiral cutter block
24 solid TC cutters produce exceptionally smooth finish
Cast iron tables and alloy tilting fence for accuracy and stability
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee may be void when used for business or educational purposes.
