Axminster Workshop AW254TS Table Saw - 230V
- Large 80mm cutting capacity at 90°
- Quiet and powerful 1.5kW motor
- Super smooth tilt and height adjustment
- Tilt and height adjustment mechanism is bolted to the chassis
- Highly efficient dust extraction from above and below
- Stand with splayed leg design for complete stability
- Raises the saw to a comfortable height
Improve both your precision and efficiency
If you’re on the lookout for a table saw to help you achieve your woodworking ambitions, look no further. Our powerful AW254TS Table Saw brings the cutting capacity of a trade workshop into the home workshop, making it ideal for many types of crafts and DIY projects. Supplied with extension tables, useful for cutting longer pieces of wood.
3 Year Guarantee
Fantastic cutting capacity
Enjoy large, accurate and fast cutting 80mm capacity with this table saw; a real workhorse of any home workshop.
Stable and robust
The ground cast iron table allows your workpiece to run smoothly across the table while the rigid rip fence offers maximum support while you work.
Achieve multiple cuts
The AW254TS allows you to achieve a range of different cuts including straight cuts, mitred cuts and bevel cuts for a range of different materials including ply, MDF, sheet materials and more.
Increased table width
As well as providing stability, the left, right and rear extension tables give you a total table width overall of 1,060mm. Useful for cutting longer pieces of wood or sheet materials.
Saw design
The motor and saw arbor assembly is mounted on trunnions bolted onto the chassis, a feature which is reserved for much larger saws. This improves adjustability and allows for a much smoother blade rise and tilt function.
Dual dust extraction ports
Keep the saw line clear with a 63mm blade guard hose connection to clear above the blade, as well as a 100mm rear outlet to clear below.
How to get the best out of your AW254TS Table Saw
Learn how to set it up for accurate cuts
Our experts show you everything you need to know, right through to making your first cut!
Choose a selection of Axcaliber blades
You'll benefit from quiet and smooth cuts, plus a long service life.
Axcaliber Premium TCT Saw Blade - 254mm x 3.2mm x 30mm 60TFrom £66.68 £55.57 -
Axcaliber Premium TCT Saw Blade - 254mm x 3.2mm x 30mm 40TSpecial Price £41.54 £34.62 was £48.88 £40.73 Save £7.34 £6.12 -
Axcaliber Premium TCT Saw Blade - 254mm x 3.2mm x 30mm 24TFrom £37.68 £31.40 -
Axcaliber Premium TCT Saw Blade - 254mm x 3.2mm x 30mm 80TFrom £81.78 £68.15
The AW254TS Workshop table saw bench brings the cutting capacity of the trade workshop into the home workshop.
The saw features a quiet 1,500W induction motor, an important consideration in a residential neighbourhood. The generous cast iron table comes with the benefit 19mm mitre fence T-slots on the right and left of the blade, allowing your workpiece to run smoothly across the table. A 254mm Axcaliber Premium 40 tooth blade, offers a maximum 80mm depth of cut for quality cutting. The full length rip fence includes a sliding sub fence with high/low functions.
The tilt and height adjustment mechanism is bolted to the chassis as opposed to the underside of the table. The result is exceptionally smooth operation and adjustability, without any weight hanging beneath the table causing stress. The tilt and height adjustments allow you to achieve a range of cuts for varied applications.
Efficient dust extraction from above the blade and below the table is brought to a single 100mm dust port for connection to an extractor. The NVR switch includes a separate locking Emergency Stop function. Removable side panels to allow cleaning and maintenance. The AW254TS is supplied with left, right and rear extension tables, giving you a total table width of 1,060mm. This is particularly useful for cutting longer pieces of wood or sheet materials.
The stand has a splayed leg design to ensure stability even when cutting large or heavy work pieces. The legs and cross braces are powder coated steel. The stand raises your saw to a comfortable height and rubber feet prevent the saw from moving when in use.
NB. The mitre fence shown in the image is an optional extra.
Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classification
These products are designed and intended for those who require equipment for more regular, but not continuous, operation. They must be maintained and serviced in line with our schedule; otherwise guarantee may be void.
Learn more| Blade Diameter | 254 mm |
| Blade RPM | 3,000 rpm |
| Blade Tilt | 0° to 45° |
| Bore Size | 30 mm |
| Dust Extraction Outlet | 100 mm & 63 mm |
| EAN Barcode | 5052511135820 |
| Max Depth of Cut @ 45º | 56 mm |
| Max Depth of Cut @ 90º | 80 mm |
| Max Width of Cut with Fence | 430 mm with R/H Ext |
| Min Extraction Airflow Required | 1,000 m³/hr |
| Nett Weight | 109 kg |
| Overall L x W x H | 1,070 mm x 1,230 mm x 1,200 mm |
| Plug Fitted | UK 3 pin plug |
| Power | 1.5 kW |
| Rating | Regular Use |
| Sound Power Level LwA [Uncertainty K] | 94 dB(A) [3.0 dB] |
| Sound Pressure Level LpA [Uncertainty K] | 78 dB(A) [3.0 dB] |
| T Slot Size | 19 mm x 9.5 mm (3/4" x 3/8") |
| Table Height | 900 mm |
| Table Size | 485 mm x 680 mm |
| Table Size With Extensions | 1060 mm x 900 mm |
| Voltage | 230 V |
